Front framerail components needed!
Ashley P
Active Member
Hayward, CA
Good afternoon everyone!
So we started cutting apart the front end on my Duster today. We knew the lower front portion of the drivers side frame rail was going to need to be sectioned and replaced, but we found a bunch of Bondo, and it looks like the two top plates will need to be sectioned as well.
Obviously, the RH side is perfect....
Problem is we cant seem to find these pieces anywhere online. Is there a vendor that has them, or can we use a B or E body set of plates?
We bought this kit to section the lower half of the frame rail, https://www.classicindustries.com/product/1974/plymouth/duster/parts/mm8154.html
Any help would be great!!
-Ashley
Check closely where the upper a-arm mounts/shock tower attach.
You may be better off sending back the cap and replacing the front section of your rail with a good used piece from a parted car. Never seen those top plates available anywhere.
Yes, this looks like the LH side, is that right? This would be what we would need if it is...
Yup......Drivers side. Let me know what you want to do.
What are you looking to get for it?
