im looking to put on a newer slip yoke when i redo my dr/sh i see a plethora of them at the local pick n pull..does any slip yoke i pick that came from a trq flite work on my 73 a833 shaft..tx..j
Only one from a 727 and don't let them tell you one for a A518 will work. They look just alike, are the same diameter and length and spline count but they changed the spline angle slightly so their not interchangeable.
napa/autozone all stock china..... See your local driveline shop and or big truck repair shop and ask for a spicer 3-3-3931 which then you'll need a joint since that is 1350 series, or neapco N729-3-1932 which is 7290 series or neapco N2-3-3575 which is 1310 and then you'll need a 5-353x joint if you have 7260 series, only consider this slip if you have the 7260 joint
