front window vent
Snake
Mopar Nut
Belleville Canada
Ok how do i get it out.I removed the screw and started to pull up on the glass it started to go but just dident want to.So is there an nut under or do I pull up harder .69 Dart..:blob:
The vent assembly includes the window track rail that can be accessed through the bottom of the door. Remove the nut and the whole thing comes straightout. The vent window is easily replaced once it's all out.
There is a bolt in the door jamb also. Behind a plug or under the forward end of the seal (I forget).
