Fuel Cell
moparstud440
Keymar, MD
How often do you guys replace your Plastic Fuel Cells or how many years have you gotten out of one before it went bad?
My plastic Jaz 8 gallon is at least 30 years old, as is the foam. The only problem is the filler cap sticks. If i can get it open, it still functions fine.
Modern tanks are the same plastic so they should last for ...oh 8-10 years until the rest of the car falls apart. Kidding, they should last a good long time. The plastic is impervious to the fuel but keep them out of direct sunlight. the UV is harder on the plastic than the fuel.
