Fuel hard line
dodgedude37
Modesto, Ca
Does anybody know how they form the end of the tube like this? I have tried several methods using my flairing tool, but I can't quite achieve this shape. Is there a different mandril I don't know about?
That's the first half of a double flare. If you have a double flaring tool, you can make one just as good.
That was one of my attempts, does the tube stick out of clamp the same as double flair?
That's how I always do it, yes. That pic up there ^^^^ is one of your "attempts" at a hose barb? I'd say it was a success.
No, that's what I am trying to copy.
The double flair part starts to form before the initial flair has a line to form a barb.
I've done some with my double flair kit. It's been a while since I have had to do it, but if I remember right, I let just a touch more tube stick out of the clamping fixture to be able to make a better bubble. Play around with it some and see, with some scrap tubing.
That's it. That's probably as good as you're gonna get with a standard double flare tool. As long as you have a barb to tighten the hose down over, you've succeeded. I'd run that.
