1974DartSport
Senior Member
How long between starts does fuel remain in the fuel bowl. Took mine apart and it was bone dry. Holley 1920. Does it evaporate?
Every time I let my dart sit for more than two weeks or so, I have to crank it to fill the bowls back up before it will fire. Someone told me that the gas is formulated differently now for the newer cars and evaporates very quickly.
That's true; modern gas has alcohol and a bunch of other additives and detergents intended for late-model fuel-injected engines. It's actually bad enough that my carb used to puke and flood my engine in hot weather because the gas would boil when it went through the fuel lines and into the hot, dry float bowl.
