btroxler
Just read an article in the Sept. Mopar Muscle mag on Retrotekhttp://retrotekspeed.com fuel injection systems. Looks like a nice setup as it uses a standard carb configuration and can handle up to 500 HP on return less and 500+ on return systems. It is a little pricey (2100) but compared to almost 1000 on more tunable Holley's it is not that bad. plus it learns as you go as it has a PCM and you can make simple changes through a laptop. It comes with all the sensors as well and there are only 3 needed so it is truly a bolt on kit. I was wondering if any had heard of them and what your thoughts were.
