fuel line reducer
eccentricMagpies
Wisconsin
I do not want to force anything on this line. So I'll post.
My assumption was that I can/could replace this fuel line reducer by removing the 'setscrew'... but now I'm not 100% sure that is it's purpose and figured I had better just ask.
Do I need to take this complete line out or will this turn off?
Also removing that screw there was teflon-like tape used. There must be something better than tape on a fuel line isn't there?
Looks like you have a 3/8" Edelbrock banjo fitting, and you want to go to 5/16" fuel line.
Looks like you have a small block ?
I would shake the Edelbrock 3/8" banjo fitting, and get the correct 318,340,360 fuel line.
5/16" pump to carb fuel line. Inexpensive, and easy to get.
What i think you are calling a "reducer" is actual a carburator fuel line
I wondered if I could reduce it further. To actually match the fuel line and filter. It seems jimmy rigged.
Someone had a solution below.
What exactly are you trying to accomplish?
Reduce this fitting/reducer/Carb fuel line to 5/16". Picture with box
Thanks. Yes, 340. I'll order this piece to the carb!
A 5/16 hose will go on that fitting. It's tight but it'll go.
That is what was currently there... and there was a leak. Felt that maybe the filter was cracked since the fuel would instantly drain back.
