Boony405hp
Hey guys,
I'm trying to build a fuel line system from my tank all the way to the rails.
I plan on using the existing fuel line off the fuel rails, but what size connector would I need to fit in to this factory quick disconnect fitting?
This is 'Riddlers' setup I believe:
I have mirrored it so far except for a few minor changes in the tank connections due to different setups. I'm unsure what connectors to use from the filter on wards to the fuel rail. I think I might run a new 3/8's hardline, are there many hardline to AN fittings available these days?
Are you guy's running a hardline or a super strong flex?
Also do all adapter fittings going in to a female AN hose have to be an NPT fitting to get a proper seal? I'm getting a bit confused by all the types of fittings and what I need to use.
http://www.summitracing.com/int/parts/rus-640940
