69signetv8
Ideas...I would like to install a 15 PSI inline fuel guage in the engine compartment. I have looked on-line ect, however all fuel (logs-rails) with "T" are for a "dual" float carb (double pumper) . The problem is I just don't what the guage flopping around laying on the manifold from a mickey mouse "T" settup attached to a fuel hose. I will still be running the mech pump and the fuel inlet for my "Holley" is on the drivers side. Without using a lot of ugly fittings and mega hose clamps has anyone completed a clean looking setup for a single float carb.
PS I thought if I found a banjo fitting with a 12 " straight line I could bend it 90 degrees in front of the carb then add a "T" but I'm not sure these lines can be bent?? This may be overkill, but would like see pics or ideas.
Thanks, Jim
Thanks, Jim
