340 swing
340swing
There is a ticking sound coming from my fuel pump. It kind of sounds like when a belt gets wet. I removed the belts and started the car the noise is still there. I removed the fuel pump every thing looks good no wear marks. I put it in a vise and pumped it manually no noise. The engine is a 360 with a double roller timing chain and a new fuel pump eccentric, manual over the counter out of the box fuel pump. Has anybody had this problem? any advise.
