[SOLD] Full set of 16 OEM valve spring retainers and keepers, SB LA, B/RB
physixx
Edison, NJ
Sold pending receipt of payment.
I have for sale a full set of 16 OEM valve spring retainers and keepers that came from a 318 LA engine. I believe that these parts will also fit the B/RB engines using a stock diameter valve spring. They are the 7-degree design and fit the OEM 3/8” diameter valve stem. They have all been cleaned and are in excellent shape. There is a set of keepers to fit valves with the 2 groove keepers, and a set to fit valves with the 4 groove keepers. If needed, I can supply a set of keepers to fit valves with the 4 grooves to substitute for the 2 groove ones. Also included are a set of 16 valve spring shims that measure approximately .055” thick. I would like to get $10.00 for everything plus the shipping.
Ken
Edison, NJ
