Hello everyone,
Just thought that I would start a post as I am about to have a complete QA1 Suspension installed on my 67 Dart.
Just a little back ground, it is a 67 Dodge Dart GT, has a 360 and I believe a 727 trans. The front is disk brake.
Will be doing the complete Stage 3 setup. Single adjustable shocks at all 4 corners. Using the large ball joint control arms.
A shop here in Kempner, Texas will be doing the install CT Performance. I will also be installing subframe connectors and replacing all the tie rods, pitman arm and idler arm.
All steering components are worn out and the stock K member was and is cracked. Has been welded before my getting the car and has cracked again. So decided to upgrade all of it.
Let me know what you guys think and as I get the pics taken I will be sure to put them here for everyone to see.
Really curious to see what it all looks like installed, can not find any pics of the rear kit on here.
I have read a lot of mixed expression of the rear kit. most relating to no tire clearance gain and the loss of tail pipes. will let you all know how it all works out.
Look forward to hearing from you guys.
