Full Energy Suspension kit need advice
Mopar King
Beginner / Need of Help
New York
I been searching around a few websites looking to upgrade my whole suspension (rubber bushing wise). Since I know the car needs an update and would like to change anything rubber under the car as much as I possibly can.
where can I get a kit with almost everything I need? Im guessing Polyurethane is much better than rubber? would like to get everything in red. do I need to know anything before buying such a kit? Size differences, shells/no shells, ect...?
I been looking at one of these kits
http://www.energysuspensionparts.com/proddetail.asp?prod=5.18104&#reviews
picture is just for reference
best kit for your money is right here... no squeks, and we have used them in every car we build, great guys and AMAZING product! just use the year make and model on the side to find your parts. oh and you have to scroll down to see the results.
http://www.performancesuspension.com/
EXAMPLE
http://www.performancesuspension.com/product_info.php?cPath=1_4593_4771_4795_46114&products_id=5915
as you can see it even comes with idler arm and upper/lower BJ's. very complete kit
AND GO POLY! NOT RUBBER
Get the complete kit. I went with it and am very happy with it. It is a great set up.
I just found this on Craigslist in Sacramento in case you are interested. Seems like a deal.
New energy suspension bushing mopar a body - $20 (roseville)
Brand new in box never used. Front end energy suspension bushings for mopar a body. 916 792 1645 $20
EXAMPLE
thanks for the link, I checked them out and it looks like everything I need. Im guessing they would have an option of color. I would like them in red so I know that it is replaced.
This kit would likely be going to my dodge demon and it was converted to front disc brakes. In case I purchase this, I should get the kit that price for $360? not the $290 .
http://www.performancesuspension.com/product_info.php?cPath=1_4593_4771_4785_46034&products_id=5914
what do you guys think of the tubular tie rod adjuster sleeves, are they better than stock? any problems? since were talking about suspension updates
http://www.classicindustries.com/mopar/parts/md47209.html
you need red bushings so you know they were replaced? how about that 300 dollar hit to the wallet! lol... i would do the sleeves if you plan on getting into handling. i'll probably be going b body stuff...
I use Energy Suspension - but I'm not a fan of urethane lower control arm bushings. Over time they can squeek and I don't like the additional road feel they transmit. So I use Moog rubber in those two positions.
Make sure you Get the correct kit. up until 72 the strut rod bushings are a different style. The 73 and up strut rods have a shorter flange to flange length and require a thicker two piece strut rod bushing with a sleeve . 72 and back are one piece usually but two piece are available without the sleeve.
An easy way to tell what rods you have is the 73 up have a coarse thread in the front the 72 and back are fine thread in the front.
Well thats just my personal taste. I would know that I replaced them even if they were black....maybe :D. Also when you look under the car the first thing that will pop out is all the red polyurethane under the car.
$300 what $300? just kidding, I know its expensive but I would like to replace everything that I can on the car since it needs it and the car is in my hands now. unless there is something else cheaper.
as for the sleeves, your saying that the new tie rod sleeves pictured are ok?
Oldmanmopar: I'll look into that, thanks for the heads up on the strut rod and bushings.
they are good! just not needed, if your worried about your old ones, you can get OEM replacments from them as well but dont know the price...
We do offer a complete polygraphite bushing set for $199 if you are interested and solid steel adjusting sleeves in 9/16" or you can upgrade to the c body 11/16" with any order over $200 you get 10% off as well for being a member here and free shipping within the US (48 States).
Here is a linking to the adjusting sleeve
http://www.p-s-t.com/s.nl/it.A/id.9500/.f?sc=12
whats your cost with upper and lower Ball Joints, inner and outer tie rods, poly boots for those, and idler arm?
If you are looking for all those items I would suggest going with a super ploygraphite front end kit. Which includes:
Lower Ball Joint Included
Upper Ball Joint Included
Upper Control Arm Bushing Polygraphite®
Lower Control Arm Bushings
End Links Included
Idler Arm Included
Outer Tie Rod Ends Included
Inner Tie Rod Ends Included
Tie Rod Sleeves Included
Strut Rod Bushings Included
Upper Cam and Bolt Kits Included
Upper Control Arm Bumpers Included
Lower Control Arm Bumpers Included
Its $449 but with the members discount is $404.10 and free shipping in the US.
But here is link to the other types of kits we offer too.
http://catalog.p-s-t.com/index.php?...hicleID=32141&engineconfigID=16194&categoryID[]=6099
Thanks
James
