[FOR SALE] Garage sale goods
superbeesrt8
mi
Rating - 85.7%
5   1   1
Auto meter 2 5/8 oil pressure gauge $30 steel braided fuel line for a double pumper holly $25 Auto meter 5 inch tack with shift light $125 Adjustable pinion snubber 35 plus shipping 741 case with 276 gears $50 A body manual steering gear box $50 2 big bolt rally wheels $20 each all parts are plus shipping
what is the condition of the steering box? Im guessing i will need an adapter since my steering column is for power
Probably so - the shaft is shorter on a PS unit but there are adapters available. Or you can replace the shaft with a non PS unit.
@superbeesrt8 if that pinion snubber will fit a 489 case I'll take it.
Yes came off a 489 case and yes you will need the coupler or get the 26 spline u joint coupler and make your own
