gas tank installation
duster 2
dustertwo
albany ny
So I am installing a new gas tank...my question is should the gas tank mate up against the spare tire well tightly..
You should put some sort of barrier between the body and the tank, I have used 30 LB roofing felt in the past. Companies like Tanks Inc. sell barriers.
Once the tank is place and it is lined up properly, I usually tighten it up so that it is 100% snug.
I am no expert, but I think that it should not have any way for the tank to wiggle around and possibly cause a hole or crack in the tank..
This is a good time to replace the filler neck seal.
Compare the old and new tank as there can be places that the new tank may need the outer flanges bent to clear exhaust, etc.
Do not use the supplied sender lock ring if included. Use the original with a new seal. With that , but the proper tool to remove the ring, a hammer and punch can push the ring into the tank lock ring and not fully seal.
Factory used a pad between the tank and body, but nothing on the straps to hold up the gas tank.
Firm and tight, no movement.
Ok...Thanks for the input
yep I used the old ring and repaired original sender and bench test it
