straightlinespeed
Sometimes I pretend to be normal
Im working on an vintage Arctic Cat snowmobile with a 6.5gal metal tank. The inside is rusty, gritty rust, not large rust flakes. It does not leak so its not beyond salvaging. However its bad enough something IMO needs to be done about it. I've been thinking I may have 2 options.
1st option is to use rust eater. I have a gallon jug of the stuff and I use it for other items and it does remove the rust, and would require me to put it in, and let it sit for a period of time, rotating the tank so it can get it all. Im assuming its some sort of acid.
2nd option is to use POR 15 tank liner kit. Looks like its just shy of $50 on Amazon.
Looking for opinions on what you all have used or done to make the tank usable again.
