Gas tank removal
It's pretty easy. Especially if it's empty. Others may do it different but I would unbolt the filler neck at the fender, unbolt the rubber cover that covers the filler neck as it goes into the tank and pull it up from the gas tank. Put the car up on jack stands. Take the sending unit hose & sending unit wire off along with the ground strap. Take the hoses off the tank near the driver side rear fender. There may be 3 or 4 if you have the ECS system on the car. Unbolt the gas tank straps and you're home free. If I've forgotten something or someone has a better way please add your input. Hope this helps. I have 2 Dusters by the way.
