Gas / Temperature sending Wire end piece
The factory original terminals at temp and fuel senders have more rubber boot on them but...
YES any terminal for #10 post would work including the one you suggested. You'll find that particular wire to be steel instead of copper. Doesn't matter. Snip the little barrel portion off something like a ring terminal insert wires to overlap, crimp, heatshrink, done. -> ()_() <-
Factory oil sender connector is where they dropped the ball. That one falls off or gets knocked off, shorts to ground, and kills gauge or limiter or both.
