R Roadart FABO Gold Member FABO Gold Member Joined Jun 18, 2018 Messages 363 Reaction score 138 Location Escalon ca. Jul 5, 2019 #1 How do I check the gauge cluster limiter out of the vehicle. Had a trusted friend check the dash and all worked but limiter was bad. He went around it to test dash. Service manual says you can do it but does not tell you how(unless I missed it)
Murray FABO Gold Member FABO Gold Member Joined Apr 19, 2010 Messages 3,805 Reaction score 3,087 Location San Jose, California Jul 5, 2019 #2 I'm a little rusty on this but- limiter has three terminals. Ground is the obvious one, then one has to be 12v in and the other would be 5v out.
R Roadart FABO Gold Member FABO Gold Member Joined Jun 18, 2018 Messages 363 Reaction score 138 Location Escalon ca. Jul 5, 2019 #3 That is what I thought but wanted to hear from others, Thanks
Mike69cuda Mopar Moron FABO Gold Member Joined Jan 2, 2018 Messages 3,485 Reaction score 3,274 Location Kansas City Jul 5, 2019 #4 If it is a mechanical OEM part, I would just toss it and buy a solid state replacement. No reason waste any time on it.
R Roadart FABO Gold Member FABO Gold Member Joined Jun 18, 2018 Messages 363 Reaction score 138 Location Escalon ca. Jul 5, 2019 #5 It is an oem unit. wanted to check before putting dash in.Not a lot of fun doing dash replacement,only hope to do it once.
billccm Well-Known Member Joined May 13, 2018 Messages 229 Reaction score 180 Location Tucson Jul 5, 2019 #6 I like the rt-eng.com replacement.
Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 14,923 Reaction score 12,285 Location Northern Colorado Jul 5, 2019 #7 If it is old mechanical style, you will need a load on the output, a guage will work, then an analog volt meter. Digital wont give you an "average" voltage like an analog will.
C Calcrenshaw Member Joined Mar 23, 2019 Messages 9 Reaction score 2 Location Tracy, ca Jul 5, 2019 #8
R Roadart FABO Gold Member FABO Gold Member Joined Jun 18, 2018 Messages 363 Reaction score 138 Location Escalon ca. Jul 6, 2019 #9 My digital reader gave me several numbers, Thanks for the help.
