[WANTED] Gear shift / turn signal knobs
big&bad
Hamburg / Germany
Rating - 0%
0   0   0
Hi @ all!
I hope you can help me - because I don't know how it's named in english...
For my 1974 Swinger...
I need these knobs, that are at the end of the column-shift-rod and at the end of the turn-signal-rod...
My mechanic broke them while restoration...
So, I need emediately some used, new or nos as fast as possible...
Please offer only complete, not broken parts...
Thank you!
You really cant replace the plastic ends on those levers. You'll need to replace the entire lever. ( Same applies to the headlight switch ). It all about how they were put together.
Great!
@ oldmanmopar: I just transferred the money, shipping is to Texas...
Delivery adress should be at paypal available, please ship as fast you can!
Big thanks to fabo!
By the way I sent you two of each. there are two different roll pin sizes on the shifter. I also sent two turn signals. The first one I took off had a nick.
Thank you very much - for me it's quite impossible to get them here...
If you need something from Germany, just let me know!
