GEN III fuel system
dodge71demon
Indiana
What is required for the fuel system when using a modern hemi in an A Body? Tank - pump - return line etc ?????????????????????????????????
You can go quite expensive by modifying the factory fuel tank and using an Aeromotive kit. I chose to go the cheaper route. This is using a LS1 external fuel pump and a corvette fuel filter. The vette fuel filter has a built in regulator that works for the Hemi and has a return line.
Here is a link to the LS1 set up:
http://www.speedwaymotors.com/LS1-Complete-Fuel-Delivery-Kit,41792.html
