Gen3 swap motor mounts
Cool Hand
Middleton Wisconsin
Anyone got a set of motor mounts for gen3 swap. Was gonna order some from tti thought I would check the forum first
Okay, I take it your QA1 K frame uses the '67-'72 smallblock mounts? They could be ordered with multiple different engine mounting options.
Sorry, can't help you there.
I think the QA1 only uses factory type mounting, no? If so, then use the conversion mounts for appropriate years. TTI is about the only game in town.
Ya was gonna order the tti mounts just thought I would check to see if anyone had a set that they were getting rid of or didn't need before I ordered them. Thanks for the reply
I’m on the hunt for a set of spool mounts for stock 74 K member if anyone has a set to unload....
