[WANTED] Glove Box Striker (Catch)
Look like what you need?
That one pictured above may work some what. But is not correct for a 72. That is 73 up. 72 would be a round tube style with flattened ends that slip between the double dash metal. and a double hole clip on top to screw it tight.
FYI, I just took this off a 72 Duster.
Could be, but the dash frame determines what style. Usually 72 back take the round style when there is a double metal area for it to slip in. If I get time I'll get a picture of one installed. Like I said it could work but it will not slip in the dash that had the early style double metal area.
This is a 72 dash frame, it has the double lip. I used the latch bar on my 70 Dash frame. It was Identical to the 1 Al posted
