goin auto.........
cudaboy 67
wales united kingdom....
finally after lots of thought ive got hold of a 727 b and m shifter and associated cables converter etc. been running a 4 speed that had loads probs so im goin auto and hopfully going to enjoy some eeeezy cruzin without heavy clutches/missing gears and general poop, in meantime after i fit the auto im going to take a look at the manual as you never know........want to wire the neutral "kill" switch / park into the equation and also maybe reverse lights .any idea which pin of the 3 does what? also im going to be installing a seperate oil cooler not thro rad as that aftermarket alloy , any idea the pressure in cooler lines? low// high? many thanks, nathan.
The center pin is the neutral safety and the outer pins are for the reverse lights.
Cooler line pressure is pretty low. Usually about 30 psi. max.
Run a big cooler if your not using a radiator with one. Especially if your using a high stall converter.
Want to get rid of your manual pedal assembly and linkages? I'm auto right now and looking to go manual.
