DusterDilly
Mopar its a way of life
whats a good but not over the top cam for the 318? Need some good ideas.
tbh i'd save the money on upgradin. just keep the 318 maintained and purrin like a kitten.
then find stuff as you go. 360 or magnum block. decent intake/cam for it. gather stuff little by little. get it all set up then one day do a swaparoo.
but like rusty said if you just want to learn the stuff and swap cams the 340 one is fine.
also if you can find an old 273 motor in a salvage yard get the rockers/rocker shafts/holddowns off it. they are adjustables... and then you could put in a solid cam/solid lifters.
oops forgot if you do grab the stuff off a 273 get the pushrods too
Moparlover is right on the money with 273, but almost all your 318 parts can be put onto a 360 or 340, so you can still modify your 318 and then swap things other once you get a good block. If you decided to just keep it stock and build a hot 360 on the side, keep in mind that a stout 360 will shred the 7 1/4 rear end most likely in your car
and i have the 8 1/4 in my car
...... Why god? Why am I the only 318 guy cursed with a 7 1/4...
I have the curse too man.:axe:
Someone who understands my plight! Lol eh, I'll replace it when I break it
thats always a good idea!!!!! i love your dart swinger!!!!
