Good member Alert
memike
Super Moderator
Staff member
on the hill
Our member lowbbudget sent me a free set "three" decals for
Our 66 Valiant Sedan "Victoria" :-D
Now she is badged up. What do you think? Have you ever
seen a /6 badged this way. I like it.:cheers:
Thank you bud.:happy10:
I'll 2nd that good member alert for lowbudget "Mike". :thumbrig:
He also sent me a couple decals that I will apply today. Any tips that you can share or was it easy to apply?
Start with a very clean area, you know that cleanliness is next
to godliness, Ok, I used my drivers license to apply mine, but a bondo spreader works good.
Just mark center on decals and on window, Then I just used masking tap on the top of mine and it held it in place, then and used my drivers license
and used it like a squeegee back and forth and up and down to be sure all the letters was applied good, Then pull the tap off " do not pull toward you or straight out" pull it off slowly and a full bend as you pull it off, then do the same with the plastic backing. Took me about 5 minutes and I hope I can understand what I a wrote down here.:read2::toothy10:
8)
Thanks Mike & Mike.......Here's a pic installed
Now pull the clear peace of plastic off, From left to right and do not bull it toward you, pull it like explained in the first post, watch and make sure each
letter stays stuck on the window!!
:shock::shock:Go over it again with your drivers license like I said and then it will let go of the plastic.
The main thing is to wipe all letters before taking the plastic off.
:sign5: I knew I needed help. What a :tard: .... #-o
How about now? Thanks for the expert advice Mike.....
Know that looks better :drinkers:
I was not sure if you was keeping it protected or something.:-D
