The 67 reverse light switches were located on the shifter mechanism when using a console application. I suppose you could use the current location with some add'l wiring :scratch:
There will be another one on the floor shift assembly. I believe you unplug this switch and plug in the one in the console....should be the same plug. You may need to build an extension cable.
