grease gun head alignment issue
Rapid Robert
Lincoln Nebraska
to grease the tie rod ends in a 73 dart I am pretty much going to need a 90 degree tip. is the tip nozzle "pipe threads" which would make for an easy fix. thank you for your time. RR
Grease gun tips and adapters are all the same thread size I think. You can also change the zerks and keep your straight tip.
