Grill Emblem Mounting?
sinstar
1970 Valiant Duster 340
Milwaukee, WI
Can somebody help me with finding the proper mounting nuts/caps/screws for this front grill emblem please!
70 Duster 340.
Thanks!
thank you Alaskan_TA & Hellrats!
do you guys happen to know the size of the 2 nuts i need fit the stems on the emblem?
Don't know the size off hand but you only need one. The small pin is to just keep it from spinning. No nut on the small pin.
7 /16" hex head & yes, it is the only fastener as mentioned.
When new, the lower peg was smooth. The nut cut the threads in it you can see in your photo.
This is not an easy area to get a clear photo of, but here is the original nut on my low mile 1970 Valiant.
Here is one out of a Duster I sent to another member a while ago;
