Anyone know where I can find a photo or diagram of the fuel tank to engine fuel line routing for a 1968 GTS. Bought a new fuel line from Inline Tube that seems mostly correct but there are some interferences. Thanks
yes 3/8 it was tight took a bit of manipulation to get in place but it fitDid you upgrade to 3/8? If so it is a bit tight! I had trouble with the first clip from rear rail to rocker. Otherwise it was smooth!
I did install at 3/8 line. Some of the bends are a bit long. For a line that is supposed to be created on CNC machines using a factory original, I expected there to be less variance. It can be made to work but hardly a drop in.yes 3/8 it was tight took a bit of manipulation to get in place but it fit
