1966 dart wagon
Well i just thought id start myself a thread i dont like posting in others topics...dont like hi-jacking threads ![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Well first off thinks John (fastback340) for throwing up pics of your dash and influencing me and giving me something to do, rather then sit here and be all upset i cant work on cuda![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
so i pulled the cuda's dash today and well a pin wouldn't come loose...this was off the revolver type connection. Well as i pulled a lil more going "dont you dare snap off" and bam it did
So now im i was ahead one step then took 2 right on back go figure ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here is the pic, it was huge so i figured id let you guys click it
could i soder it back on? or how can i fix this, i believe it was the purple wire that it was connected to(have to check which wire that is for) any sugestions.
also got any tips for fixing my guages...oil and temp dont work? The wires to the guages are all there, and together(tested with ohms meter). How do i install white faces. Sugestions on sanding? how about painting and cleaning the lenses? how can i make a corner piece where it was broken(near glove box) could i use some filler to make something then sand it smooth?
Thanks guys :thumbup:
