I ended up with orange peel in the camaro pictured above. It wasn't bad and most people would of said it looked great. But if you can prime/paint a car what is one more one step with wetsanding. Isn't to hard.
Took 1500 followed by 2000 sand paper and then buffed it out with 2 different style pads and compounds. Smooth as glass now and still need to do the last step with wax and a dual action style buffer.
I have found out it seems like single stage enamel and urethane tend to lay much smoother when its all said then done compare to a base/clear set up.
Enamels take longer to cure and inherently lay out flatter, because of cure time.
The best thing you can do with a base/clear system is to take your time on each panel/ section you shoot for a reasonable layout.
I turn the gun down to about 35-40psi, which renders me about 8psi at the cap instead of ten. I get a lot less cloud, but I've got to make the fan a touch narrower and bring the gun in just a bit closer.
I end up going through less material and the way the pattern lays out on the panel from the beam allows me to control the finish look, as I am painting each coat, especially the first coat, because I'm putting on less material, it stays static on the panel instead of wanting to move.
It also means that I have more flash drying between coats. I give it about 20-30 minutes between coats and repeat the process. I don't like laying it on heavy to achieve gloss, because the final layout requires the paint to flow, in order to achieve a smoother finish if you do that and gives you unpredictable results. It also gives the paint more reason to sag or run, if you try and put it on wet.
If you go over an area and pass it relatively quickly, you can pass it multiple times somewhat dry and eventually, there will be enough material on the area that the beads will begin to grab each other and flow. This is the way to know how much material you are laying out, instead of just trying to get gloss out of one pass. It puts on just enough material to control it and because it is very little material, you have more control to keep it as it looks, each time you coat it. By the 2nd or 3rd coat, I've walked away from jobs that simply don't need polishing to look as smooth as I want them to, because I keep the coats light and let the beads of paint on the panel do the work, with multiple, light passes, instead of letting the beam from the gun give me the gloss on a single pass.
As an example, when I go over a panel, I will pass the entire panel light enough to leave a dry look if I walked away. It would have the texture of a formica countertop laminate. I do it again and usually by the 2nd or 3rd pass, the beads on the panel start to find each other and flow out. I consider that one coat. This all happens within about the same amount of time that it takes to do one full pass with the gun, but I have a much better idea about exactly how much paint is on the panel and I can be sure that the entire panel is getting the same amount, because I can see it in the reflection as I'm doing this.
Once I've achieved gloss on the first coat, after the 2nd/3rd light pass, I check everything with a bright LED light to be sure everything is even and leave it alone for a half an hour before coming back in to do it all 1 or 2 more times.
