I found this back on the shelf that I did not know existed.
It is the legendary 9800 Performance Carter Superquad.
These are calibrated and designed without the emission
junk on the production carbs for High performance.
They require no modification to the circuits the original
carbs do to run properly.
Everything moves freely and it is complete even the electric choke
is in place.
I disassembled it to make sure it was intact without damage.
However, it needs a good cleaning before I would install it
but I am incredibly fussy on the race cars.
$275.00 plus $24 Shipping and insurance
Make one hole larger for a Mopar throttle piece or put a bolt in it.
If you have a street automatic that still uses the kickdown linkage =
Holley makes a bracket to accommodate the carb for all the Mopar kickdown stuff.
Add $35.00 and I will buy and install it for you if needed.
is in place.
