So, you take an early Saturday morning just as the sun comes up or an evening just as the sun drops below the horizon to wash your special Mopar. You take care not to let the soap dry on any part and you carefully dry it off so you don't leave any water marks. But when you take it out for a drive the next day, you can barely see out of the windshield because of the water marks on the window! What is the secret of a perfectly clean window? Windex sure doesn't cut it. So Gang, what should I use??
