[WANTED] HARMONIC BALANCER FOR 225 /6 "1963" Valiant Auto
It's in good condition. I removed it 6 months ago from a running, driving truck I had. I'll take $20 for it. I'll send a picture of it tomorrow. I'll need your ZIP code so I can get you a shipping estimate.
All years are not the same, so, you may want to state exactly what engine, year, model, transmission, and forged or cast crank.
per the other members comment : What car did your harmonic come off of? would it be the same as to my 63 slant six 225 (Valiant) with auto trans,
The one that I know I have is from 76 D-100 w/manual trans & it's a cast crank. I may have another one that was off a 74 Duster with an auto. but not sure if it was a forged or cast crank. I'll see if I can find that one & get pics too. Both were the 225 engines though.
Assuming your engine has stock parts, the interchange is '63-6 all size car slants, '63-8 pickups, and all transmissions. The A100 vans use a different balancer for some reason.....maybe timing mark location? Starting in '67 cars, they moved the timing mark on the outer ring. Most balancers will mount and work if you're willing to remark the timing slot, but, there are some that don't work quite as well depending on options such as P/S and A/C. Some of the '70's and '80's trucks have balancers with multi-groove pulleys and are a bolt-on rather than press (hammer) on.
How much was that
The last one I had done was thru the damper dudes and I believe they.offer lifetime warranty, would have to check on that
