Harmonic Balancer Installation Tool Questions
Hyper_pak
Old School Chrysler Fan
Desoto Texas
Need to press a ROMEC on to my slant.
I used to pull the stock ones on with a long crank bolt.
But the ROMEC is thicker and I need a tool.
Any recommendations?
Please don't recommend all thread and a nut.
Thanks
Get a Lisle brand balancer puller, the one with a hollow jack screw. The jack screw is the same thread pitch as the Mopar crank bolt so you can thread the jack screw into the crank and use a nut to run the balancer on while holding the jackscrew with its 1/2 hex end. Nothing wrong with all-thread and a nut as long as its the right size, that's what the dedicated installers use anyway.
