Has anyone tried one of these car lifts
Pawned
N.R.A. Lifetime Member - And damn proud of it
Valle del Sol, AZ
Tilting Car Lift
I just ordered one for about 50 some dollars, delivered.
Hope it works like the ad shows
So... I replaced my front struts on my Caliber last weekend. I pulled up on Rhino ramps, put a floor Jack under and jacked up off the ramps. Then chocked the back tires and Jack stands under the frame. I had a tire off in about 2 minutes.
The good news is I'm sure harbor freight or whoever sells this hunka **** will honor the warranty for your widow.
I might trust it if the pads were longer front to back.....and with a LIGHT car. But then, that brings on new problems like the frame needing to be longer front to back. I wouldn't have a good feeling about it. You live everyday. You only die once.
I'd like it more if it didn't pivot. If it stayed solid and didn't teter, it may be a decent option for a quick brake job and such.
It would be good to have the option to lock it in place. I wonder if it does? I didn't see that it did. Kinda worries me they may not want it pickin a whole car up at once.
