Hd 904
A/MP
What year did mopar make the HD 904, '75-'76-'77? I think its the 998. Is there any way to tell by looking? Thanks
998 and 999 trans was late 70's and up. you'll have to check the numbers on the casting to verify it, as they all look the same. More often than not, the 998 999 had a lock up converter, so a look at the input shaft would reveal a fluid passage in the end of the shaft.
