superdave
I have popped a head gasket on my 360(coolant leaking out side of block only)
Can I get away with replacing my .040 thick gaskets with a .028 thick to gain compression without any valvetrain problems?
Ratio now is 9.55-1 and have stock non adjustable valve train.
Also is it normal for a gasket to blow only on the outside of block?
Engine runs fine, no coolant inside,just pukes coolant between head and cylinder..
Thanks!!
Dave
Thanks!!
Dave
