ben littleton
Active Member
what do you guys time your cars with a 2 barrel at, with vacuum signal plugged? mine is on ported vac so I shouldn't really have to plug it.
No,gallon for gallon.i thought it was a 'pint' of water for every gallon of gas.
Plug it. Its common practice.what do you guys time your cars with a 2 barrel at, with vacuum signal plugged? mine is on ported vac so I shouldn't really have to plug it.
it definitely doesn't boil over or run hot, it ran at the bottom of the "healthy" window all week in 95 degrees!If its a little rich,the water and soot are a telltale.
Head gaskets have specific symptoms,boiling over at highway speed,white exhaust and a very clean cylinder.
Or coolant in oil pan.
Lots of cars spit water on cold starts.
There you go. Not a head gasket.it definitely doesn't boil over or run hot, it ran at the bottom of the "healthy" window all week in 95 degrees!
