I would definetly move it. I used a laser heat indicator and found the header tubes on my car run 500+ degrees. 3" away isn't very far and in the summer it will most likely vapor lock. It will also cost you some power by the hot fuel heating up the carb resulting in a hotter/less dense intake charge.
