Headlamp Wiring problem
69akcuda
New Member
Ketchikan, AK
I am currently working on a headlamp issue on my 69 Barracuda. Just replaced the headlamp switch hoping that my headlights would not turn on when turning on my parking lights, still does. Have checked the front harness, not found anything yet. Any thoughts and were to start/continue.
did you check the bulkhead connector???? it might have a short somewhere in there causing the headlights to come on with the park lights on the first notch of the switch... i would check the dash harness as well.. the problem might be in the dash not the front harness...
