Headlight buckets
70Duster340
Cortland, Ohio
Can someone here give me some ideas of where to locate some sort of diagram that shows how the headlight buckets are mounted? When I bought the car (1970 Duster) it was equipped with fiberglass fenders, and previous owner had just used the trim rings for the headlights to hold the headlights in place. No obvious way to adjust them. I have a set of the buckets, I just need to know how to mount them.
Thanks much!
All Dusters are welded on like the ones pictured but they can be bolted in place. The 70-72 Darts are bolted on. You will need these to attache the buckets to the fender
Thank you, sir. But the buckets I have already have the adjusters and springs. The fiberglass fenders have a panel that looks like it's designed to hold the buckets.
You can see this in the attached photos.
Does anyone have any experience with mounting headlight buckets in a fiberglass fender? I don't wanna screw this up, but I can't find anything on the Internet that seems helpful.
