Headlight Question
Robert Noble
Member
Perry Mi
Converting 74 over to 70 front end. I have latch bar assembly, grill. Still need filler between bumper and grill if there is one out there. My question is are the headlight buckets the same and in same location as a 70?
Thanks Robert.
1st mopar build have allot of questions
Not sure this will help but... I put a 74 fender on my 67 dart thinking all 67 thru 76??? fenders were the same. Found out they are not. The headlight mounting was the same but the bezel mounting was different. Also at some point 74 I think, they added crush ribs on the top of the fender where it mounts to the inner fender panels. I might be off a few years here and there but you get the idea
Thanks Robert.
It does help if the make and model are included in questions.:D
"I thought" I knew that 67 was the only oddball
All I know is when I went to put the headlight bezels on, the holes in the bezel did not line up with the square holes in with the fender.
