edbux
What type/PN relay is used when putting then into the headlight wiring?
Thanks
Thanks
just use standard bosch 30amp relays you can get at a local parts store.
I went the Painless route with a harness already made up. I think it was part number # 30815 but not exactly sure. It just plugs into the stock wiring headlight plug and of course you got to hook up to the alternator and ground. I then went with Zoop H4 headlights. It made a world of difference. It's not the cheapest way out but it was the easiest way LOL!
http://www.painlessperformance.com/...earchAll=Classic Cars&refinesearch=Relay+Kits
Not dissin' the Painless products at all, but if you want to be informed on headlight issues, check out Dan Stern's site:
http://www.danielsternlighting.com/
Light 'em up!
Light 'em up!
