Small Block
I've got a Ford 1 ton dually. 94 model and it seems to have developed an issue with the headlites blinking on and off. Not sure if it's the on/off switch on the dash of the hi/low lever on the column. When they go out i can pull the lever back to me and they will come on and remain on high if i hold it to me. It seems to be more of an issue on high more so than on low. Where do i start? Looking at the Haynes manual now.
Small Block
Small Block
