earthmover
in the tire smoke
1 915 j heads ported with comp cam springs,lock, and milodon valves flow (if i remember correct 240/150@500)
heads was on 340 for a while went 7.40@90mph with a sick 60' of 1.67..pick wheels up and set them back down and spin the wheels ...in a 70 duster ..$550.00
2. 915 j heads ported with comp springs and lock tulip (stock type) valves no flow #'s but have been almost as fast as the first set just didnt do any tuning took them off and put the other set on with new valves...$500.00
both are set up for soil cam 555 lift was the max i ran on both heads....
3.torker 340 intake port matched 125.00
4.440-2 indy intake for rb motor and valley tray powder coated gray..valley tray has the center you can remove with vac. port for gauge hook up $400.00
5.73 dart washer tank with the little motor on it(dont know if the motor works or not)$25.00
6.mp blue valve covers small block has a small ding in 1 cover that i pushed back out 50.00
7.170 6cylinder is what i was told it is..took apart but have most all the parts$50.00
buyer pay shipping on all parts,parts located in nc,and will post pics tonight or tomm...have link to some parts now..mike
http://i1123.photobucket.com/albums/l548/bigmike540/utf-8BSU1HMDAxMDAtMjAxMTEyMTgtMTUxMy5qcGc.jpg
http://i1123.photobucket.com/albums/l548/bigmike540/utf-8BSU1HMDAxMDEtMjAxMTEyMTgtMTUxNC5qcGc.jpg
http://i1123.photobucket.com/albums/l548/bigmike540/HPIM0651.jpg
http://i1123.photobucket.com/albums/l548/bigmike540/HPIM0653.jpg
http://i1123.photobucket.com/albums/l548/bigmike540/utf-8BSU1HMDAwMDgtMjAxMTA3MDUtMjAyNC5qcGc.jpg
440-2 intake and heads..heads have some surface rust from setting..had them plastic wrapped but took them out a while back when someone was suppose to buy them and never did...more pics to follow thanks
small bolt axle 75.00 need new studs
