Heat control valve spring
Slant 6 Engines
  1. 66Dirtydart
    66Dirtydart Well-Known Member
    105
    57
    Aug 20, 2019
    Tacoma, WA
    Local Time:
    3:21 PM
    Are the heat control valve springs and hardware reproduced? My 170 has no springs on it. The valve isn't seized, but has been stuck in the "cold" position.
    I've got it all apart to replace broken hardware and put in a set of Remflex gaskets and would like to restore the function of the heat control valve while I'm in there.
    Thanks!
  2. slantsixdan
    slantsixdan =..=
    6,757
    1978
    Jan 7, 2007
    Vancouver BC
    Local Time:
    3:21 PM
    Having a working heat control valve is an excellent idea. The '60-'64, '65-'69, and '70-up style Slant-6 manifold heat control valve hardware is all unavailable as a new-stock or repro item; it's going to be a go-fish deal for old-stock parts, except if obtained as part of a new exhaust manifold (not necessarily a bad idea if you're going to the R&R trouble, unless your pre-'70 manifold is in unusually good condition).
    • Like Like x 1
    • 66Dirtydart
      105
      57
      Aug 20, 2019
      Tacoma, WA
      Local Time:
      3:21 PM
      Thanks Dan, it was a long shot. This is a 1964 170 manifold that doesn't appear to be cracked. I'll see if I can locate a used spring and if not I'll look into a replacement manifold.
    • slantsixdan
      slantsixdan =..=
      6,757
      1978
      Jan 7, 2007
      Vancouver BC
      Local Time:
      3:21 PM
      Check the manifold carefully not just for cracks, but also for flatness of the gasket surfaces and for warp in both dimensions.
      • Like Like x 1
