HEI conversion- which e coil?
that dist all ready has a coil in the cap, why noy try it first before replacing it?
That is the big cap unit. You may likely run into clearance issues with that one.
You may want to contact @Johnny Mac from Blueprint Engines. He sells much better fitting distributors than that one, that also have an HEI mini module. for less $ than that too. I believe those big ones hit the wiper motor...
My first thought as well.
About $50 on ebay...small base GM hei style dist. Got mine thru skipwhite.
Fits the v8 A body very well.
Works awesome on my 360.
2 wire hookup, blaster coil and that's it.
